Madman
- Sun Prairie, WI
- 252SD
In the last 15 years, I never had a need to remove a jet pump on my boat. I know I was probably overdue, but with just over an hour on the new boat, I had to load it back on the trailer and head home. I watched a couple of videos to get the basic idea and got to work. As many of you know, it’s a pretty straightforward process, but since the service manual for my boat isn’t available yet and it looks like there are some differences with DriveX, I’m wondering if someone has a service manual and might be able to answer a few questions.
1) After disconnecting the nozzle, I wanted to disconnect and remove the reverse gate so I could get it out of the way, but I couldn’t figure out remove the e-clip due to clearance issues. Is there a process for disconnecting/removing the reverse gate.
2) What, if any sealant is used between the nozzle and impeller housings?
3) What, if any sealant is required between the impeller housing and the transom plate.
Any help would be appreciated!
