Fuel Injector Cleaning
DSCLLC
Temple, Tx
Does anyone routinely pull their fuel injectors and send them to someone like Injector RX for testing and cleaning? A friend just pulled them from his older Yamaha jet ski with about 100 hours on it. They were tested to be fair to poor, but were able to be cleaned to like-new specs. It was about $90 including shipping for the four of them.
Just curious if anyone else does this on a routine basis.
I have done it before with my boat I think it was less than 200 for all 8 with enough insurance to cover me to by new ones if something happened I could a difference when I did mine
If you're having some issues you may want to try a can of Sea Foam first.
Of course they would say they are fair to poor. If they said they were mint you would never send to them again. At 100 hours seems way to early.
Good fuel, some additives and no worries.
No need to send out unless there was an issue narrowed down to restricted injectors.
Think about how long automotive injectors go. 100k, 200k, 300k, hell ive seen 500k on a sienna and its never seen an injector issue
These injectors are just like automobile ones.
Save your 90 bucks for something needed
He was having issues with rough starts, loss of power, etc.
I built a crude injector flow tester with an adjustable pulse driver and 40psi pressure tank for feeding cleaning solution. They all looked perfect, even the test injectors i got from an 80s mustang. I don't think it was worth the effort. I've tested 8 mr1 injectors and some 21lb Ford injectors and they all looked great as far as the flow pattern. None leaked at 40psi.
The tank
Sonicator bath cleaning too
Can that be used to inject cream into a cannoli?
JetBoaters.net - The World's Largest Jet Boat Forum!
I
  • Injector Masters Welcome to JETBOATERS.net! We are delighted you decided to join the forum and look forward to your contributions! We hope that you will enjoy the features the forum offers, and enjoy the collaboration with all the members. Some things you might want to check out as a new member are linked below. Also, this message will disappear after you've posted 5 messages, or if you click the "X" to dismiss it to the right. Don't forget to add your location (you'll be added to the map automatically!)Forum FAQ
    Order Forum SWAG Here--Stickers, flags, Tire Covers, and more!
    Forum Features and how to use them
    Member Tips and Tricks forum--lots of member ideas here!
    Forum Rules, Financials and more
    Tips on how to use the forum: On your phone, the Lightning bolt at the top shows you the same as "What's New" on a larger screen-this is a list of the active topics being discussed right now. Click on the hamburger Menu on your phone (3 Lines in the upper left) to see a list of ways to get around the forum. The "Forums" menu item at the top of that list would, for example, allow you to navigate to the "Member Tips and Ideas" which has a sticky (post that always stays at the top) for how to diagnose why your engine won't start. Hope this helps get you aquainted with the basics! We look forward to your contributions/questions/input!
  • As the forum gets bigger and bigger having a consistent approach with members regarding the Code of Conduct becomes harder and harder. Fortunately our forum software has a feature that can help us all. It is called "Warnings". The purpose of the feature is to give a member a "nudge" from a moderator that they've crossed a line, and gives the member an opportunity to change course. Please be sure you read this postto ensure you understand how this works. Admins/Moderators will begin using the Warning feature April 13th.
    You can dismiss this notice by clicking the "X" in the upper right>>>>>>
New guy not very good at this...
Unwatch
I
Injector Masters
New Member
5 minutes ago
Hi all!
I was invited to join the blog because someone saw what I do and thought it might be valuable and of interest here.
My name is Wayne and I'm an alc... oops. Wrong group.
My name is Wayne and I'm a gasoline fuel injector test/clean/rebuild guy. I have 11 years experience and the newest and best equipment designed for this purpose. My company is Injector Masters, and we service all 4 stroke and 2 stroke gas injectors from marine and land based applications. We use the ASNU equipment which is unmatched in the industry.
I've built this company based on friendly, quick and professional service with proven results. We diagnose, then treat and ultrasonically backflush, then retest every set. Upon passing final tests for leaks, flow rates at varying rpm (balance) and spray patterns we assemble each injector with new filters/seals/grommets/spacers etc as applicable. Most are included with a few part numbers being a few extra bucks each. Injector service is far less expensive than replacing yours, and we don't believe in cheap aftermarket replacements. Most injectors perform ASNU ? upon final analysis and replacements are seldom needed.
We typically just take 1 day for service then have your supplied set on its way back to you. We are able to work with Etec and Ficht injectors as well for those Johnson and Evinrude fans.
I'm no good at this blog stuff. I will do my best. We can be found on Facebook @ injectormastersllc with the black and white logo, or on the web page Www.injectormasters.com that has email and phone information and lots more.
Happy boating season if that's a thing for you. Some of you get to play all year-round. Lucky you!
Quote Reply
Report •••
Remove formatting
BoldItalicUnderline
Text colorFont size
Insert linkInsert imageSmiliesInsert
Gallery embed
AlignmentListInsert table
UndoRedo
Toggle BB code
Write your reply...
Post reply Preview
Attach files
Similar threads
Share:
FacebookTwitterRedditPinterestTumblrWhatsAppEmailLink
Forum software by XenForo® © 2010-2019 XenForo Ltd.
Parts of this site powered by XenForo add-ons from DragonByte™ ©2011-2021 DragonByte Technologies Ltd. (Details)
Well, looks like you got a little extra in your post, but I found the heart of it. Welcome! Appreciate your reaching out here.
So, a couple of professional questions, then, please;
1) When you recommend an injector service? Are there particular signs/symptoms that should make us think 'injector problem'?
2) Recommendation early on here was, 'try Sea Foam'. I don't normally disagree with that advice. Do you agree?
3) If we do need to send a set to you, what are we looking at for our Yammi's? $50? $500? $5000?
Great to have you here! Thanks.
Edited to add: Oops, looks like you have a double post here. Don't answer here--I will put it to your main post (that doesn't have the extra stuff). Thanks!
1/2) keeping your fuel system clean and maintained with good fuel and proper storage is #1. Seafoam is a great additive but people tend to over add to their fuel systems. Seafoam is not needed every tank of fuel. The better maintained a fuel system is the less likely it is to exhibit injector related symptoms. Those can range from no start, hard start, rough idle, smoking, sluggish acceleration, low cruise rpm, hard restart etc.
I am not a "pull the injectors first" advocate. It is typically a process of elimination that leads one to suspect the injectors. That's when we come in.
Or, if the injectors out of the engine for some other work being done, is a great time to have them serviced.
Proper fuel system maintenence is the key.
3) standard gas injectors are $25 per injector, direct injectors and air injectors are $35 each, upon passing final testing and including the test report, new filters and seals per injector.
Whew!
Really?!? One day? Shoot...
For what the dealer charges for a 10 hour service, I could have the injectors all done twice. And a heck of a lot faster.
Thanks! Good info!
