Help me pick a trailer tire
What tire would you go with?
  • Total voters
JBehrens
Huntington Beach, Ca
Hi guys, need to replace the trailer tires, blew one on the way home last weekend and now I don't trust the rest. After doing some research it looks like the Maxxis M8008 and the Goodyear Endurance are the two options in my size (205/75R15). Both seem to have an equal level of failure with maybe an edge to Goodyear as being more reliable. Cost is about the same, I'm leaning slightly to Goodyear (always a fan of Made in the USA) but if you had to what would you go with? Are there other options I should consider?
Thanks!
marcham
Comox, BC
AR195
I've had great success with Maxxis on my travel trailer. That being said, if money is no object, I'd go with goodyear.
Tranquility Base
I would go with the Goodyear tire as it has a N speed rating-87mph. Not that I’ll be towing at 87 mph, but because most ST tires are only rated at 65 mph. Dealt with a lot of the pos made in China ST tires over the years and finally arrived at Michelin XPS Rib tires on my RV, since thise are not available in your size S well as mine I’ll be going with the Goodyear’s.
Babin Farms
Lower Alabama
I put 4 of these on at the beginning of last season and they have probably over 4,000 miles on them with no issues. Made trips from Illinois to N. Michigan, Coralville IA, Destin FL, and all over our local area. On the interstate I usually travel at 80mph and the local roads are crap but these tires are holding up. One thing I recommend if you do any long distance towing is to have whatever you buy balanced.
rad1026
Albuquerque/Havasu
I stopped in a trailer shop in Havasu a couple weeks ago. They make custom boat and heavy equipment trailers. The told me the best trailer tire they have ever used is the Vision Marine Heavy Hauler. I looked it up when I was out there. Rated at 81 mph at 115 degrees. Made for high heat conditions. Discount tire is a dealer. I went ahead and put them on as the local Discount had them in stock.
rad1026
Albuquerque/Havasu
JBehrens
Looked them up, they look nice but unfortunately do not come in a 15" rim size.
DJ Bellin
Pensacola, Florida
I just put Good Year Endurance tires on this year. I have had stock bias tires and generic radial and have had blow outs with each. I have only put about 500 miles on the trailer this year but they have been great so far. I will be traveling to Florida in a couple weeks from DC area so I can report back after our vacation. I think other tires are probably just as good but I always buy American if I the price isn’t that much higher.
fatboyroy
Sebastian, FL
I rolled with Good Year Endurance across the country in my RV (way heavier than my boat) in 2019 for 3 months, covering about 15K miles with no issues. You should be A-OK with your trip.
JBehrens
3 green tornados
Southern CA
212X
Thank you for that! I make the trip out there often from so. California and have lost two tires to the heat.
JBehrens
A decision was made, boat now rides on Goodyear Endurance with a second spare. Thanks for all the input, we shall see how these do.
Tjw961
Olive Branch, MS
I did the same brand last season and has been doing well thus far.
Berrie
Kansas City, MO
Monterey
Goodyear Endurance is good, I have also heard a lot of good things about Hercules (they make mostly semi tires).
The spare on my Bayliner trailer now has a Hercules, haven't used it yet.
On my Monterey trailer I run Arisun. They are Chinese, but have held up well so far.
JBehrens
Put the first 1100 miles on the Goodyears last weekend, so far so good.
JBehrens
What wheels are you using? And where did you buy them ? Thanks in advance
Wheels are Raceline 840's that came with the trailer. I bought a spare directly from Raceline 840 Arsenal
RobbieO
Sacramento River Delta
212SE
80 MPH? If you tow at 80 MPH in CA, you're going the the Gray Bar Inn.
Babin Farms
Lower Alabama
Just keeping up with traffic in most cases. Been towing bigger trailers with a lot bigger loads than a boat for a majority of my driving life and am comfortable doing things with trailers that most don't even think of.
