Show us what you see!!!
Very cool @scot71 !! Do those engines move from station to station while being built or are the built individually...as in each engine by one person?? Also, how many can be built in a day??
@scot71 ............. Incredibly KEWL video. So many thanks for sharing.
A few questions. When you are done (with a "typical" power plant .......... whatever you consider typical)
1) How many cylinders are in it 2) How many people worked on the power plant during it's build and testing ? 3) How much power does it develop in operation ? 4) HOw much does this weigh ? and 5) Is there a typical HP rating ? Thanks, Mikey Lulejian - Lake Oconee, GA
I'm glad you liked it. I have to admit, even after all this time that I've been there. I'm still very impressed by what we do.
Ok, let me try to answer your questions.
The 3500 series engines come as either an 8cyl, 12cyl, 16cyl, or 20cyl. We used to make a 24cyl that was made from two 12cyl engines mated at the crank. I'm not sure we still make that one.
The 3600 series comes as a straight 6cyl, 12cyl, or a 16cyl.
I'm not sure what the total number of people that touch every part of a finished engine would be, but I know that 14 people will touch each block during the machining process before it is ready to go to assembly.
As for power. There are so many different configurations that I really have no idea how much power they typically produce. We make engines that run on diesel, natural gas, propane, and a blend of diesel and gas.
I'm not sure about weight either. I was told once that a 3616 Gen Set out the door will weigh somewhere over 90 tons.
Like I said, they still impress me.
Thanks Jim, happy to share. The 3500 series is primarily built on a line and the 3600 series are individually built by I think two or three people.
As for how many can be built. The most I remember us having to build was something like 54 a day, but that was before the economy tanked in 2009. For the last several years we've been in the mid 30's a day on the 3500 series and 1 to 1.5 a day on the 3600 series.
That is still quite a few engines in a day!! Toured a Cessna plant once and it was amazing!! The plant was over a mile long and each plane would spend a certain amount of time at a certain station then move on until it was completed. I forget how many planes they were working on at one time or even how long it took to complete one from start to finish. Biggest plant I have ever been in for sure!!
My work bench this morning...
Most of those quart cans hold a product called void filler. Mostly used in the aircraft industry. GE motors will use this product inside the cowling to give the blades something to spin against when the turbines crank up. A 1/2"X 1/2" X 1" block, once cured(5 hours at 120F) will take in upwards of 2000 psi to crush. Very light weight.
I'm always amazed at the manufacturing capabilities we have in our country and the wonderful people that work in the various industries. Now if only we could get these companies to stop sending everything overseas. Now if you'll excuse me, I need to go study my mandarin language lesson. :rolleyes:
Jim ....... This is amazing. Sorry but I didn't "get" anything you wrote. Being retired is a TERRIBLE waste of a mind ....... LOL !
Sounds like sumptin' I could use around here ... So if I can paraphrase ......... "
...this product inside on @MikeyL will give him something to spin against when the Barbie cranks up ..." .... OK ?
Nope....Chicago....the building in the distance in the center between the other buildings is the Willis (formerly Sears) Tower, and the other tall building on the right is the much newer Trump Tower.
That brings up so many great memories! My uncle used to drive for Exxon in the Hampton Roads area and he would tske me with him. I would sit on a a box in the cab because there wasn't a seat for the passenger. Great pics!!
@Jim Robeson that's cool. I am from Newport News, VA and used alot of Exxons in the area :)
I sincerely hope this is OK ............
While waitng for the "GRAND ANNOUNCEMENT" by Yamaha @ 11 AM today, and as reported on by @Murf'n'surf .......
I was sent this today. I snopes.com checked its validity .........
'Jes lending more credibility to Quality reporting ........
