Sonic Blue
- Ontario Canada
- 252SD
1). I was told not to run the hose until replaced.On #1 you are saying it overheats on the hose but not on the water? The only "valve" is the one right at the flushport that gets pushed in by the hose adapter dohicky to prevent backflow when the engine is running and in the water. Does water come out of your pissers and from the transom when on the hose?
#2 makes no sense, of course the pressure generated by the impeller is greater than when being towed, but the difference is that the engines are running so no water can backflow into the engine. Makes me question why he said its an issue for SeaDoo's. Not sure about the Rotax powered boats, but on the SeaDoo skis the engine cooling is closed loop. Only the exhaust cooling is fed from lake/ocean water.
2). Ya good point. I’m just putting it out there for feedback like this. Thank you. .
