Wash hose quick connect totally stuck - FSH190
leftcoasterfl
Bokeelia, Pine Island Florida
FSH Deluxe
Hello from Eyewall City - aka Pine Island FL.
My hose is totally stuck. We made a couple of runs from the island to the Cape for supplies in the last few days and we plugged in the hose.
To start - the hose works great. It really sprays out like a normal garden hose. Now, I cannot get it out of the quick connect. It is totally stuck. It is so stuck that I can unscrew the center brass fitting, but that is no help :) So we did a run with it connected and the nozzle worked well enough to keep the water from spraying. So, now the hose is just lying on the deck.
I have sprayed it with WD40 and even have tried channel locks. It wont come out? Any ideas on what to do next?
Glad to be alive ;)
Tranquility Base
Did you try pushing in on the fitting then push the release collar on the outside of the fitting?
Tranquility Base
Sounds like a piece of debris might have been inside the female side of the fitting and it got jammed in there.
Had you used the wash down hose before?
TeenGee
Florida Space Coast
Any luck rotating the collar on the female half with channel locks while pushing in the male half?
TeenGee
Florida Space Coast
I feel your pain.
2004 was the worst year.
Charley
Frances
Jeanne
Tranquility Base
If you are unable to get the hose out, go and look at freshwater systems web page as they are the supplier of these parts to Yamaha and sourcing those replacement parts at freshwater systems will be cheaper than buying through Yamaha. If you need assistance let me know. Long story short, I lost the male quick connector late last summer and found it at freshwater systems.
Pretty sure you can buy them on Amazon really cheap too.
Tranquility Base
Right on…
Due to the supply chain issues it took some time before they got their stock replenished… I looked everywhere and no one had them at that time. I’d have to go back through my emails with them and look for the part number. I know that freshwater systems sells the female and male sides as a kit. If memory serves, freshwater systems bought the company whose name is embossed on the parts, I’m pretty sure it was @lazergeek who pointed me in the right direction.
Last summer when we rented the houseboat at Lake Powell we were using my wash down hose to keep the water slide wet and the male fitting was removed from the hose and the hose was attached to the outdoor shower of the houseboat. On the second to last night there was a huge wind storm and things were rapidly stowed at 2 in the morning and that was the last time it was seen.
Tranquility Base
Here’s the kit with a plastic male connector
This is the better brass / plastic male connector.
More expensive on Amazon…
A quick search didn’t turn up the female side on amazon…
Pretty sure Yamaha wants close to $200 for these pieces…
leftcoasterfl
FSH Deluxe
The hurricane totally trashed my front door so I took all day to hang a new door. :)
Ill be able to check it out tomorrow. I thank everyone for the advice. Ill let you know. Cheers!
Tranquility Base
Any progress?
leftcoasterfl
FSH Deluxe
Well - looks like this is going to work.
I just got rid of the quick connect. It actually broke when I tried getting it out again...so I bought this
Solid Brass Hex Pipe Coupling 3/8" Female NPT Air Fuel Gas Water | eBay
And it worked and adapted both sides. I rarely use the hose so having to screw it on when I need it is no big deal. Ill just cap it and take it off as needed.
I am happy this was a cheap fix :)
Tranquility Base
Great!
You know there is a sea cock shut off valve right under the mechanical access hatch in the clean out tray? Unless you want the hose totally out of the way you could just turn off the supply valve when you don’t want to use it.
