girthquake
 - Irvine, CA
 - SX
This is my first post on this site, however, I have been lucky enough to learn much from many of you so far!
We purchased a used 2006 SX210 back in June. Low hours, started up and ran, all looked great. I put in new plugs just so I had a baseline.
1st real trip we launched and the boat ran great for 20-30 of cruising and getting to know the Jet boat.
Stopped for a bit and the port motor took a while to restart. Didn't think too much of it as it started up again right away each time we stopped.
After our second trip, we noticed the port engine did not like to start after a prolonged break. Sometimes it would take a long time to get it to start.
As soon as it started, it would run great with no problems!
On our third trip, after our initial cruise, we stopped for lunch and the port engine refused to start. We idled back to the ramp and went home.
I swapped the plugs from the port and starboard and the port engine fired right up and the starboard would not start so all new spark plugs went in and then both engines ran fine again.
We went for a weekend trip and the first day the boat ran great until another prolonged break...Then the same issues happened again.
After this trip I pulled the Port engine and just for fun replaced all gaskets and cleaned all that I could while having the engine out. Injectors looked clean and brand new almost. Replaced fuel lines and put in K&N air filters. Put the engine back in the boat with new plugs. Filled with oil and new oil filter. Started on the hose, ran for a while. All tested fine. Saturday we took the boat out for a test run. Port engine started right up and ran great. Oil levels great. Purposely turned it off after running for 5 to 10 minutes to see if starting issue happened again. After two or three times, we turned off the boat and floated having lunch. Finally, it happened again. Port motor would not start. After trying intermittently for 10 minutes, it finally started and ran rough for 15-30 seconds, then, it jumped to running smooth. Ran fine the rest of the day as long as we didn't stop for long periods of time.
Very weird.
It is almost like the plugs are getting fouled and it will not start until they dry out. If I start up right away after stopping, all is fine. If we sit for a bit, this seems to be the problem.
Could this be electrical? Fuel pumps are working. Is an injector sticking after we turn off the fuel allowing them to fill the cylinders and flood the plugs?
If I put brand new plugs in, it will start immediately every time.
Any advice would be greatly appreciated!!
Very weird.
