AR250 Range
HangOutdoors
Royal Oak, MI
Anyone with an AR250 get an accurate max range on a full tank of gas?
adrianp89
Tampa Bay, FL
252SE
No idea but I would estimate at least 125 miles.
HangOutdoors
Royal Oak, MI
I had seen the initial test results but looking for some real world usage info.
adrianp89
Tampa Bay, FL
252SE
One of the guys on here has run to Bimini in his 252SE that should be about the same if not less range. @jacoviii I think he might have some feedback.
Theoretically you could do close to 180 miles.
Tranquility Base
@HangOutdoors are you just curious or is there a developing plot here?
HangOutdoors
Royal Oak, MI
DogDadDave
KY
After 22 hours our lifetime average is 2.0mpg for our 2022 AR250. The caveat is that I'm... throttle happy. I would say that a quarter of that, if not more, is WOT. At least a few are also no wake zone at 3-5mph. Bimini is always up as well which I'm sure adds some drag. We have zero time towing a tube/wakeboard/skier at the moment. I believe I've averaged 2.4 or 2.5mpg while cruising around 30mph.
So your numbers are in line with boattest's:
Wheelspin
I've done 125 in a single day in my 21 SX250 with the bimini up, occasionally flat out, but generally around 35 mph when not in no wake zones. I was showing slightly under 1/4 tank left, and I put 50 gallons in afterwards.
Matt Phillips
Lake Tahoe
Total distance on a tank of fuel can be a relative term and variable due to current, wind (going with or against for both), how much weight is in the boat (including people), and also elevation if on a lake). For example on Lake Tahoe, without even touching the throttles, if the wind changes on a given course, I've seen it affect my speed by as much as 5mph - and that's with the Bimini up and 5-6 people on board. On my current tank, the computer is telling me about 2.2mpg at 6200 feet of elevation.
