FSH 210 Sport
- Tranquility Base
- FSH Sport
Because the Ohm value of the winding in the pick up coil is changing due to heat, crank position sensors do the same on their way to failure. Having said that, even when cold a bad pick up coil will be out of range when cold. You’ll need a shop manual and a good ohm meter to test the pick up coil, check it cold then check it if the engine doesn’t want to start. The symptoms you describe of how it is getting worse are a bit classic for a failing pick up coil from what I’ve read here. Check it and eliminate it as a possible cause.Had a Scarab. Sold it and have had the 242x for 3 years. I usually cruise into the no wake zone in no wake mode where we tie off or anchor out and that never makes a difference. The boat is firing. It will try to start, but sputter and fail. Sometimes you have to crank it numerous times before it will finally keep running. This is definitely temperature related. I don't see how the pickup coil could be out of spec when it starts first crank every time cold, and also every time hot after it finally starts.
Try the no wake mode at level three in neutral for 15 seconds then back to idle then shutdown once you’ve stopped just to be sure.
