Babin Farms
- Lower Alabama
We had that problem once, or twice, maybe 3 times. Now we put about 5 concrete blocks around the bottom on the lower rails. No problems since.Just got the trampoline back in the yard after it went for a tumble last night in the 60+mph gusts. The anchor was 2’ deep and pulled out by the winds. Looks like I’m repairing the netting posts….again.
I'm going put the anchor back in the ground and have a sand bag or two on each leg to help it outWe had that problem once, or twice, maybe 3 times. Now we put about 5 concrete blocks around the bottom on the lower rails. No problems since.
R.I.P. Dusty Hilland @zipper could stop by that shack just outside La Grange, a haw, haw, haw, haw
Took my Mom, Aunts and Uncle to and funded an Indian Casino trip as an early Xmas gift. It’s 2 am, we’ve been here since just past sunset. I’m ready to leave, they are not.
Where are these 70 somethings getting their energy?
It's called life is short. live in the momentTook my Mom, Aunts and Uncle to and funded an Indian Casino trip as an early Xmas gift. It’s 2 am, we’ve been here since just past sunset. I’m ready to leave, they are not.
Do you give these away or have a big family gathering??? Our willpower is too shitty to have too much good stuff like that around!!!That time of year - pecans are roasting, caramel is melting - Xmas candy cooking!
New generation of chocolatiers learning the craft.
These little boxes will all be filled with candy, and then some, they usually make between 40-50 boxes in several batches, tonight was the first batch, and the crew looked a bit rusty so they need to pick up speed tomorrow.
How's that truck treating you in the harsh weather? Heated seats and steering wheel have to be nice. 4wd with the aut rear locker helps in the snow as well I'm sure.The warm weather, in the 50's, this week was nice to get a couple of things done without snow cover. I knew it would not last long, 6" overnight and still snowing. Nice to have thru the Holidays, then it can go away.
My jack handle is definitely my breaker bar too, although I’ve snapped the drive right off a craftsman 1/2” ratchet doing that and I havent tried again since.Mom's '07 Escape had some brake issues. aBS ring was broken in the end of the CV shaft. Have to replace the entire shaft because the ring is press fit in place. After running to AutoZone for a 32mm socket, I had to improvise this madness to get enough torque on the axle nut to get it off....
Whole time I'm singing in my head "Time to do some sketchy shit doo-Da; Hope I get away with it doo-Da"
It worked and I didn't die!
Thanks.My jack handle is definitely my breaker bar too, although I’ve snapped the drive right off a craftsman 1/2” ratchet doing that and I havent tried again since.
I’ve never seen the pickle fork jackstand trick. That’s pretty clever!
