- Knoxville, TN
- Limited S
One of 4 conditions I'm betting:
1. Spark Plug change (our boats are notorious for fouled plugs causing issues)
2. Dirty Hull (Julian lost 15 MPH a few years ago after leaving the boat in the water. When he cleaned it, his boat was approaching 50 again)
3. Throttle stops (I was only getting 44 ish when I first took out my current 242LS. I found that the port throttle was not getting all the way to the fully open throttle position, so I adjusted the throttle to remove all slack at WOT. She instantly started getting to the 51 MPH as advertised)
4. Banged up impellers (This is huge. However, you usually notice cavitation when the issue lies with the impellers)
