- Tranquility Base
- FSH Sport
I looked for a similar thread that was posted before, but my patience was somewhat limited so just decided to make a new thread.
One of the very few downsides to a jet drive is trolling in the wind, with the worst being wind coming from astern as it will push the boat, and then the trolling motor, while in cruise control, slows its prop speed to try and maintain the speed selected which leads to loss of directional control and the boat will start to skid. This isn’t as much of a problem with an outboard or I/O as there is a big rudder sticking down in the water.
Yesterday I had an epiphany that I should have had a long time ago on how to control the skid / slide problem. On a whim I tied one of my dock lines to my five gallon bucket handle, dropped the bucket off of the stern about five feet back, ran the rope through the center mounted water sports tow hook and secured it to a stern cleat with a couple of cleat hitches. I could have just put a bowline in the line and secured it to the water sports hook, but I wanted to be able to adjust how far back the bucket was as part of the experiment. As it turned out, I left the original length and just set the bucket on the swim step on the upwind legs.
This worked out great! The bucket / drogue provided enough drag that trolling motor now had to increase thrust to maintain my 1.8 mph trolling speed, and the bucket / drogue was providing enough drag to hold the stern in line with the bow. I do think I’m going to try a small drogue instead of the bucket as the bucket was about maxed out on how much drag it could supply.
In the past I’d just leave the trolling motor in the water for my upwind leg, but I’d use the engines to provide directional control, usually using reverse and splitting the throttles to maintain speed and correct for any sliding or skidding. Now I think by using a large enough drogue and perhaps vary its opening I’ll be able to use the troller for a wider range of conditions before having to go to the engines.
@fatboyroy @Liveto99 @dels @HangOutdoors
