Welcome to Jetboaters.net!
I will be interest to hear how this stands up in real use:
"Turning was crisp and sharp at all speeds and the new hull design also had the added affect that when one let go of the wheel while in a turn, the wheel and the boat immediately centered up on a smooth straight path."
Would love to see some video of driving in a straight line with no wake mode engaged and off so see how much course correction one has to make. Can you point it and let go of the wheel and generally hold a course?
Im also curious about the tow point being farther back. With hard wake crossings will the stern keep from wagging? Maybe the new keel/rudder helps with that?
The tow point on mine is damn near center of the boat.
It will want to self-center the wheel. If you point it off center and let go the wheel will tend to return to center position, not hold the position you pointed.
I agree it will be interesting to see how straight a path it takes.
Curious to know if the keel is an upgrade that fits some of the older boats. That definitely caught my attention and I would consider adding if it was available for my boat.
Looks like it might be a great mod. Wait and see results and see when they post the parts on the yammi parts page. Im def going to be paying attention!
Great info. Do you think the keel and rudder combo is enough to keep the boat on a straight course with very little to no input of the steering wheel while at no wake speed?
I really don't have that much of an issue with this on my 242 LS with Thrust Vectors and the "TDE" setting. A little more when not in TDE, but really not that much... I wonder if the TDE helps more than I realize.
I can see how the TDE would help with slow speed steering, since it points the water down and not out, giving it more of a "bite". We have the older style cobra steering. I can keep the boat relatively straight at no wake speeds, but it requires my constant attention... If I take my eyes off of where I am going for more than a second or two the boat will start to spin. If I let go of the wheel in no wake mode the boat will just sit and spin in circles. If the combination of TDE and the keel and rudder fix that issue, it would be a huge improvement for Yamaha's boats.
@Volffas, there is a huge difference in straight line handling between the original cobras and the current extra large fins. My LX210 had original cobras which worked great with the smaller lighter boat. My SX230 came with original cobras which did not do much for it at all. I upgraded to extra large fins (I am staying out of the which fins are better argument) and find my SX230 to be quite stable and have much better slow speed maneuvering ability.
I will have to look into a set of new fins then. We REALLY love our boat, but my only real gripe is how terrible the slow speed steering is. My wife is a pro at driving at speed, towing wakeboarders,tubes etc.. , but she REFUSES to drive at no wake speed in crowded areas because the boat keeps getting away from her.
If the articulated keel were an add-on option (which would be very curious to see how that would be possible), you would have to adjust your trailer bunks for sure to avoid ripping it off .
I have the cobra 16x fins and while they do help IMO you can't let go of the wheel without the boat tracking to the left. Within a few second it ends up going in a different direction. Was worse prior to the fins.
My 2cents
