Jim_in_Delaware
- Southeastern DE
- Boatless
- NA
- Other
- Other
The new batteries for the land toys (three Polaris Ace UTV’s) came in earlier today. These are YUASA AGM sealed batteries that are made in Reading, PA. Interesting thing about these powersport batteries are that they are shipped dry and you add the electrolytes (sulfuric acid) to the batteries. Pretty easy to prepare: remove (and discard) the foil sealing strip from the top of the battery, detach (and save) the black sealing strip from the electrolyte container, place the electrolyte container upside down on the now open battery filler ports, push the container down to break the aluminum seals allowing the electrolyte to flow into the battery, remove the empty container from the battery and seal with the black sealing strip saved earlier, wait two hours for the electrolyte to permeate the battery plates, and then charge.
Jim
Jim
