Sub is now completely installed (well, other than the nameplate.) Wiring pulled, terminated, connected at sub end, sub mounted. Happy to have that done - was a bigger PIA than anticipated.
@mark_m ........... Nice mods. I just wanted to TRY and help ya out a bit and let you know, that after extensive research, we here @ jetboaters.net have concluded, after consulting with some of the best medical minds available in the world, that there is NO CURE (ie, "MOD SICKNESS").
Sorry to be the bearer of this bad new to you.
Hey ! Happy Memorial Day upcoming to you ! Miokey Lulejian- Lake Oconee, GA
Not really. A couple of the bolts were a bit a reluctant to come up...they all had a bit of grit in the mounting hole threads.
I just removed them slowly and carefully, and I used a vacuum once or twice to suck away grit as I was backing out the bolts. Else, no significant trouble.
Did you use a #3 Philips bit inbuilt into a socket and a 1/2" ratchet? I started to fear stripping the Phillips head of the screws into the fiberglass.
I believe I just used a screw driver. It has been a couple weeks of frenetic driveway boating, trying to get mods done as season here is now really getting started.
After almost loosing a finger last weekend I decided to replace the POS spring that is supposed to hold the anchor locker door open. I used a 15" gas strut I picked up from Auto Zone. While I was at it I removed the ladder that we have never used but is in the way every time we use the anchor.
Just put on my new cover, charging batteries and enjoying the new sound system.
Picked it up Monday from the week long install.
Added 4 Roswell tower speakers, 6 JL Audio interior speakers, sub and amp.
Really happy with it!
Love my charger! It is currently plugged in at the dock at Conley Bottom Marina, Lake Cumberland. Bilge pump on!
Seriously, it's been great and has kept my batteries in pristine condition. I used it all winter while my batteries were in the basement to keep them in great shape.
What onboard charger do you use? I have a duel battery set up on my 2007 232 Limited and would love to have an onboard charger. Are they easy to install?
If the scratches are significant you'll probably want to hit it with very fine wet/dry paper first, then maybe some polishing compound as @tdonoughue mentioned. Don't go crazy, it's under the boat.....
That may be hard to cure right next to the newly installed keel guard. But it is just polish and buff as @tdonoughue said, but because of the guard, your going to have to work right up against it.
