Missionboatgear Delta
Joey Martinez
Conroe, Tx
SeaDoo
I bet these will work on jetboats to help make surf waves for all you surfers out there. Seems like the same thing as Malibu and axis surf gate system.
http://www.missionboatgear.com/collections/delta-wakesurf-panel
looks like they want 498 for it
http://www.missionboatgear.com/collections/delta-wakesurf-panel/products/surfside-universal
I emailed the company asking if they have tested it on a Yamaha Jet Boat. I made mention that there is this user forum full of boat owners with Mod money burning a hole in our collective pockets looking for something like this. Haven't heard anything back as of yet!
Not going to say that it will not work but................. I talked to Ronix about their wedge block eight.3 and this would be the same type of convergence system that this would be doing. They said " It didn't work on a Yamaha but it did on a Chaparral."
I would love to test this unit in conjunction with the wake wedge. I think this combo has potential.
So did you call them to ask for a test unit?
Do you have wake wedges for 242x's?
@Julian I have not called yet but I do plan to. Yes we do have Wake Wedges for the 242X. In fact we have already setup a 242X that Jeff Page, owner of Inland Surfer, has surfed behind.
Wait...what?...where's the video?
No no no...the 242X with the Wake Wedge. That's what I want to see.
This is similar to Ronix wake surf shaper, etc.
I think @trace tested something like it and the word was that, while it works great for inboards and may work somewhat better with a single jet engine as opposed to a twin, the jet wash pressure is still too high preventing the convergence even if the wake is delayed. Which, if true, is too bad...
@buckbuck go to my Facebook page, I shared the video.
Hi Guys, thanks for all the interest! DELTA has worked on every boat we've tested so it might work here. We had some initial concerns about safety but in chatting with one owner it sounds like Yamaha fully supports surfing behind their boats. We're going to cruise into the local dealer and see if we can locate a boat to test it on. We'll report back shortly. Cheers and thanks again!!
@MISSION_BG Please keep us posted, hopefully you can test both single and twin Yammies. I would be the first to jump on it if it worked.
You have a pretty steep non-adjustable angle that seems a lot more aggressive that the less then 30 degrees or so the other designs seem to be like. Any trouble keeping the Delta attached? I remember there was a discussion on Malibu forums about possible advantage of velcro over suction with lateral forces. Your design would work great with Yammies with their sloping aft free-board. And - it looks cool.
Welcome aboard @MISSION_BG and thank you for looking into it. If the dealership route doesn't work then check out the member map to look for owners close to you - we love showing off our boats!
@swatski @Scuba_ref Just got back from the dealer and they gave us the green light. We're going out this week for a test run on a 242x and hopefully we can also run it on a single engine model. We'll let you know how it goes. Here's a photo of it attached to an AR230.
If you need a single engine guinea pig and are anywhere near Wisconsin I'm your man! @MISSION_BG
@MISSION_BG Ha! Good idea to join the group....told you you will find very interested people here!
