Welcome to Jetboaters.net!
Went over that bridge hundreds of time on my way to Newport/Goat Island (proposed to my wife there). Never under it. Looks like a beautiful day. Thanks for sharing.
Three rolls of flex seal. Two small ones for the waverunners and one large one for the boat. Hopefully I will never have to use them but I’m happy to have them onboard.
Mechanical Engineering and Hockey, well I liked hockey better then. But the Engineering took me further. My RA was a Marine Bio. major. Had a few dorm friends that thought they were too. They would put on their scuba gear and raid the Lobster pots out behind the dorm closest to the Bridge, at the time. They knew the risk.
I see a lot of new finished woodwork laying around that needs to go to the boat (Beneteau). A complete new set of Cherry/Holly sole panels to replace original Mahogany/Black panels, a new cherry liquor cabinet cover and a Sugar Maple block that sits over the gimbaled stove. A surface to put the induction burner on in the galley.
EDIT: It is pretty cool how the grain changes with the light, flash. This is it without the flash.
Just in case I ram the dock (again) and put a hole through the hull (again).
I also plan to use it to patch some leaks in my inflatable mats. “As seen on TV”, as purchased at Home Depot ($20 for the large roll, around $12 for each small roll).
I’ve only used it once so far to patch the base of a portable basketball hoop, the $hit works as advertised, like Tape with 3m 4200 as adhesive.
YES !
It is a copy of one I saw a while ago on THT. A guy made one for his Grady White.
All the SS hardware and SS Tubing can be found online.
It's made to remove really very easily, but I have only removed the Sunbrella and SS poles once when trailering from Wisconsin to Florida..
It's good for highway use because the hardtop creates an air burble.
My longest tow since the move has been from Tampa to Fort Lauderdale...
I was certain you had seen the commercial of Phil Swift, the Flex Tape inventor, cutting a boat in half and repairing it with Flex Tape, then taking it out on a lake. Classic infomercial stuff.
