HangOutdoors
- Royal Oak, MI
So I was trying to determine at what level (PPM) is CO2 concerning. I came across the following, and it suggesting that up to 1000 PPM, can be deemed typical of occupied spaces. Any thoughts?
Several threads on it in the forums.
If you ever thought carbon monoxide poisoning could not happen on your boat, read this | JetBoaters.net - The World's Largest Jet Boat Forum!
Its basically ppm over time which can build over multiple exposures during the CO's half life. So even minimal time with high PPM over repetition on same day could cause a lethal build up. Or minimal PPM over shorter time with repetition can cause a lethal build up.
It also builds up in the body and doesn't vacate quickly. The half-life of carboxyhemoglobin is approximately 5 hours. This means that for a given exposure level, it will take about 5 hours for the level of carboxyhemoglobin in the blood to drop to half its current level after the exposure is terminated. Which means multiple short sessions have a period of a long session, this is typically what causes the grave circumstances on a boat. Furthermore it isn't just the amount of time you are exposed, it is also about PPM over time, so a broad statement such as "Not long" is of no significance unless you can determine the PPM rate. A chart below for reference, that I copied.
PPM CO | Time | Symptoms |
35 | 8 hours | Maximum exposure allowed by OSHA in the workplace over an eight hour period. |
200 | 2-3 hours | Mild headache, fatigue, nausea and dizziness. |
400 | 1-2 hours | Serious headache-other symptoms intensify. Life threatening after 3 hours. |
800 | 45 minutes | Dizziness, nausea and convulsions. Unconscious within 2 hours. Death within 2-3 hours. |
1600 | 20 minutes | Headache, dizziness and nausea. Death within 1 hour. |
3200 | 5-10 minutes | Headache, dizziness and nausea. Death within 1 hour. |
6400 | 1-2 minutes | Headache, dizziness and nausea. Death within 25-30 minutes. |
12,800 | 1-3 minutes | Death |
Since you don't vacate it the moment you stop inhaling it, is where things can get bad. If you re expose during the day (check Half Life of CO in body) then it just adds and adds.
