- Northern Vermont Lake Champlain
- Other
- Other
- Other
A fellow employee just had his tractor tires filled with beet juice, apparently it doesn’t freeze, condense or expand. Each tire/rim weighed around 300 lbs when filled.Breaking down and changing an old sun cracked front tire that leaks air with a new one.
Dunno if it's beet juice, but there's some form of liquid derived from beets that they spread on the roads here prior to snowfall to help with melting or removal or something.
^^ Looks like a 190 with a tandem axle trailer. Interesting.
Close to records here from what they are saying on the news.Florida is going for a February heat record, supposed to be in the 90s this weekend.
I’m trying to get out into Tampa Bay this weekend. I think the water is still a little too cold to go to Egmont Key and anchor to walk the beach. Any day on the water is a good do tho.Florida is going for a February heat record, supposed to be in the 90s this weekend.
It’s a 210…. You can tell by the location of the ladder and the clean out hatch seams, and I know the pumps are hard to see but you can see the two whitish colored zinc anodes..
