- Northern Vermont Lake Champlain
- Boston Whaler
- Other
A fellow employee just had his tractor tires filled with beet juice, apparently it doesn’t freeze, condense or expand. Each tire/rim weighed around 300 lbs when filled.Breaking down and changing an old sun cracked front tire that leaks air with a new one.
Dunno if it's beet juice, but there's some form of liquid derived from beets that they spread on the roads here prior to snowfall to help with melting or removal or something.A fellow employee just had his tractor tires filled with beet juice, apparently it doesn’t freeze, condense or expand. Each tire/rim weighed around 300 lbs when filled.
Interesting. My rear tires, inner tubes, are filled to the top of the rims with calcium chloride. We use it on this hilly land to keep the tractor from tipping over. If an inner tube leaks there is salt everywhere and rusty rim internals. I do not fill the front tires.A fellow employee just had his tractor tires filled with beet juice, apparently it doesn’t freeze, condense or expand. Each tire/rim weighed around 300 lbs when filled.
It looks like there's transom straps on that thing, maybe it's a bigger model, or perhaps the trailer is/was for another boat? Regardless, it looks like it's riding nicely on that thing. I think you were talking about having issues with the boat centering on the trailer, and that one looks bang on.^^ Looks like a 190 with a tandem axle trailer. Interesting.
Florida is going for a February heat record, supposed to be in the 90s this weekend.
Close to records here from what they are saying on the news.Florida is going for a February heat record, supposed to be in the 90s this weekend.
I’m trying to get out into Tampa Bay this weekend. I think the water is still a little too cold to go to Egmont Key and anchor to walk the beach. Any day on the water is a good do tho.Florida is going for a February heat record, supposed to be in the 90s this weekend.
I wouldn’t stand in the water for an extended period of time but it’s fine to jump in to walk to an island. I was in it last weekend.I’m trying to get out into Tampa Bay this weekend. I think the water is still a little too cold to go to Egmont Key and anchor to walk the beach. Any day on the water is a good do tho.
It’s a 210…. You can tell by the location of the ladder and the clean out hatch seams, and I know the pumps are hard to see but you can see the two whitish colored zinc anodes..^^ Looks like a 190 with a tandem axle trailer. Interesting.
Makes more sense!It’s a 210…. You can tell by the location of the ladder and the clean out hatch seams, and I know the pumps are hard to see but you can see the two whitish colored zinc anodes..
