- Northern Vermont Lake Champlain
- Other
- Other
- Other
Here’s my wood eater
It can handle a 2k sq ft house good but much more & I can’t keep enough wood in it. I run a heat exchanger in the plenum of the furnace and a sidearm exchanger on the water heater. We keep our place between 66-68 & that seems to be a good temp for letting the boiler keep up. Due to living in the middle of nowhere with no hills or tree lines to stop the wind I probably go through about the same amount of wood as you @zipper without heating the garage.
I ended up hanging a Hot Dawg in the garage and keeping the temp set at 45. View attachment 141419
Bad pic. but this is the beast.
I have seen 1300° in the reaction chamber temp. reading. 300 gallons of water in this thing.
