- Northern Vermont Lake Champlain
- Boston Whaler
- Other
While I'm in my hotbox of a shop your out on the boat.
I could rub it in with more pictures, but I won’t, out of respect for your circumstances.While I'm in my hotbox of a shop your out on the boat.
Good tip. There is a store near me that stocks PS, I’ll have to check it out. Brats sound reasonably easy. Definitely need to move us to kielbasa.Plenty of different seasonings here for anything that you may want. I prefer the #278 Jalapeno mix for brats with some hi-temp cheese mixed in.
PS Seasoning: Sauces & Rubs for Home Cooks, Sausage & Jerky Making
Our Seasoning Rubs and BBQ Sauces make home cooking easy. Shop award winning flavor profiles, browse recipes, and learn how to make sausage like a pro.www.psseasoning.com
Do you have a sausage stuffer? If not I’d get one. The attachment that go on the grinder are ok but you’ve got a lot more control with a press. I’ve got a 15lb LEM press similar to this.Good tip. There is a store near me that stocks PS, I’ll have to check it out. Brats sound reasonably easy. Definitely need to move us to kielbasa.
If you like the process and get into it, you're going to find yourself quickly outgrowing that attachment.I can do now (got the grinder for the Kitchen Aid last year) What is your recipe?
This would be the first time. I thought I had the attachment for the KitchenAid mixer, but I don’t.Do you have a sausage stuffer? If not I’d get one. The attachment that go on the grinder are ok but you’ve got a lot more control with a press. I’ve got a 15lb LEM press similar to this.
My brother is good for unnecessary kitchen gadgets, I’ll have to see what he has.If you like the process and get into it, you're going to find yourself quickly outgrowing that attachment.
Head over to smokingmeatforums.com and try to avoid spending days over there
I've got the stuffer from KitchenAid and with the auger moving things along like with the grind process, you have to keep an eye on your temp as it adds a pretty good amount of friction heat.This would be the first time. I thought I had the attachment for the KitchenAid mixer, but I don’t.
Good to know. Do you have the metal or plastic one? I’ve heard the plastic one is total crap, and the metal one good, but isn’t perfect.I've got the stuffer from KitchenAid and with the auger moving things along like with the grind process, you have to keep an eye on your temp as it adds a pretty good amount of friction heat.
The one that @Babin Farms has, or one like it, is the way to go for sure.
We have the plastic one. Never used the metal one. But, from what I know about the plastic one, what you've heard about the two doesn't come as a surprise.Good to know. Do you have the metal or plastic one? I’ve heard the plastic one is total crap, and the metal one good, but isn’t perfect.
Hair of the Dog. He just got bit!
